PWHT per API 620
PWHT per API 620
PWHT per API 620
Dear Experts
We are going to construct Isomerate above ground storage tank per API 620. The compression rings on this tank are 88mm thick of A573 Gr 70. As per API 620 I was not able to find PWHT requirements of Carbon steel welding of this much thickness. Please guide whether PWHT of this compression ring is required or nor, If anyone can share the reference of code?
Thanking all in Advance.
Farhan
RE: PWHT per API 620
I don't see a requirement for it- looking at 5.25.3 and 6.18. Nor do I see a thickness limitation.
That said, a compression ring that thick would certainly be uncommon, and it would be preferable to adjust roof slope, design pressure, or compression ring configuration if possible.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
