Settlement characteristics in Tuff Rock
"Tuff (from the Italian tufo), also known as volcanic tuff, is a type of rock made of volcanic ash ejected from a vent during a volcanic eruption. Following ejection and deposition, the ash is compacted into a solid rock in a process called consolidation. "
You can't dig into Tuff rock with showel but need to use demolition hammer.
What is your experience about Tuff Rock.. especially weathered tuff rock? Can it cause foundation settlement too? To what degree?
RE: Settlement characteristics in Tuff Rock
Quence,
You're broadly categorising what is already a blanket term for a rock type...just as with clay-derived rocks, the properties of tuff relate to its geochemistry.
We get some tuffas in central Africa that weather rapidly into a horribly active clay soil, whereas in our southern regions, we get siliceous tuffas that are completely inert, relatively hard and welded.
If you require a demolition hammer to remove the stuff, I can't see why settlement would be a concern. If you want to know the properties of your tuff specifically, you will have to go and test it. If durability of the rock is a consideration in your design, test for this carefully, including microscopic examination of the rock thin sections.
All the best,
Mike
Where is the tuff located? Brisbane tuff is very hard, with negligible settlement under high rise buildings. Makes for excellent tunnel boring.
What do you make of lithic lapilli tuff? Its also called adobe. Why is it called adobe? Can it settle?
UCS, structural orientations, presence of water, nature of discontinuities. . . BAM, you get the RMR (rock mass rating) or the GSI (geologic strength index).
So, you need core, RQD and other such etcetera and you'll be in a better position to describe the rock-mass properties.
Some of these rocks can degrade. So, durability can be a factor as the rock mass of today may not have the same strength as the rock mass of tomorrow.
Good luck, but we just don't have enough information.
f-d
ípapß gordo ainÆt no madre flaca!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Smart Manufacturing for Semiconductor
New technologies and approaches present great opportunities for semiconductor manufacturers to achieve high levels of innovation, yield and improvement. This white paper explores some of these cutting-edge technologies and how they can be applied effectively in the semiconductor industry. Read about how Smart Manufacturing is transforming the semiconductor industry. Download Now
White Paper - Analysis and Simulation in Aircraft Structure Certification
Organizations using simulation and analysis tools effectively see the benefits in their ability to achieve certification faster and with drastically less total cost than those who do not maximize these tools. Read this White Paper to learn about how digital tools such as analysis and simulation help in aircraft structure certification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
