Annular and Bottom Plate of a Crude Storage Tank.
Hi all,
Could someone kindly clarify what the intended purpose, salient features, differences and the construction w.r.to shell plate of the Bottom and Annular Plate is?
What implications does it have on the tank design?
Also, what is the Diameter-Height ratio prescribed by the norms?
Thanks and Regards.
RE: Annular and Bottom Plate of a Crude Storage Tank.
Can you restate your question ? ... I do not understand
MJCronin
Sr. Process Engineer
Do you mean what is the annular plate? It's the piece of the bottom plate just under the tank vertical shell plate.
As for the tank D/H ratio, it can be less than 1 for the field elected tank as the adequate space is permitted, and higher than 1 for the shop fabricated tank.
There is no one answer to the height/diameter question. If there are no other considerations, the (estimated) cheapest set of dimensions will be used. However, those dimensions will vary depending on the contractor, the foundation requirements, coating requirements, plate availability, etc. If the whole tank and foundation is a package, you can let contractors pick desired dimensions for the capacity. Note that certain H/D ratios will be better or worse for allowable bearing, wind overturn, seismic overturn, etc. Typical shell heights will be multiples of the commonly used plate widths (so, in the US, you get 24', 32', 40', etc., based on 8' wide plate).
An annular ring is normally used in cases that generate higher stress in the bottom plate, or those cases where the plate near the shell needs to be thicker than the remaining bottom. The normal (but not universal) practice is to use an annular ring only in those cases where it is required by API-650. Generally, large tanks, hot tanks, tanks in high-seismic areas.
JStephen gives solid advice ...There is no one answer to the height/diameter question.
If this is your first major flat bottomed tank, get help from an experienced engineer
MJCronin
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
