self actuated pressure regulators
we are having two self actuated pressure regulators on LPG Line to plant having inlet pressure of 270psig and set pressure of 14.7 psig.
the capacity of each regulator is 230kg/hr of lpg.however it was learnt that the capacity should have been 315kg/hr of LPG for each regulator.
these regulaors have been procured and installed at site.
now question is how to ensure that these regulators provide 315 kg/hr of LPG in place of 230kg/hr?
or a third regulator in pararllel is the only answer?
RE: self actuated pressure regulators
You want to increase the flow by 37% I expect that would cause a significant drop in pressure, only the designer of vendor can tell you if it's possible without more detail.
Regulators with a pilot regulator (small regulator controlling a larger valve) tend to have better flow characteristics because it acts similar to a pressure amplifier
