CATIA V5R21 64bit DO NOT WORKING on Win 10 PRO 64 bit
Dejo
Aerospace
Aug 2, 2018
Hi guys,
Can someone please help me resolve problem.
Catia V5R21 64bit DO NOT WORKING on Win 10 PRO 64 bit.
I hope someone knows the answer.
Thanks!
I don't understand the list from 3DS, which oneis V5R21 for W10?
The short answer is V5R21 is not supported by Dassault, meaning most probably if you want to try to use it on Win 10 64 bit you will have some problems.
Even more, you can notice on that link which releases are under support if you are a usual customer.
If you really need to work with R21 then you need to downgrade your Win 10 to Win 7.
Fernando
- Romania
- EU
Thank you for info.
I know that we will use R27 with W10, is this V5-6R2017?
As W7 will not be supported by Microsoft in short while then W10 must be used.
