Barrage structural design steps
Did any one have any guiding documents on the above topic. Your help will be greatly appreciated.
Ravi K
RE: Barrage structural design steps
When you design a Barrage, you go through the normal steps. Define your loads, define your layout, choose an analysis approach, verify that your members are adequate for the loads, etc.
Oh yeah, what's a barrage? Isn't that where the enemy shoots artillery at you for a long time?
Thanks JedClampett for replying.
By Barrage I mean, a type of low-head, diversion dam which consists of a number of large gates that can be opened or closed to control the amount of water passing through.
I have attached a pic of the same (Ref: Wiki)
Ravi K
You may want to search the construction details of barrages in the Columbia river within the State of Oregon (USA).
Chicopee, I wanted to model the components of a barrage in software tools and the barrage can be any barrage. If you have construction details of barrages in the Columbia river within the State of Oregon (USA). That will also be helpful. Thanks
Ravi K
designing any sort of dam is a large undertaking with many different issues to address. I'm sure you must know some of this, so it would help if you indicated which area you are interested in. For example, to name a few:
  • hydrology
  • hydraulics
  • scour
  • sedimentation
  • structural
  • foundation
  • seepage
  • settlement
  • constructability
Here are a couple of good starting references, available online:
USBR Design of Small Canal Structures
https://www.usbr.gov/tsc/techreferences/mands/mand...
USBR Design of Small Dams
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
