Will the joint affect the analysis in this case?
I don't know why there some joint on the beam and i cannot delete them. How can i delete the joint on that beam.
Also, how can i combine those wall? I think they may be divided by grid line.
Thanks a lot
RE: Will the joint affect the analysis in this case?
You can merge shells within the 'edit' tab.
