Here is my issued
I have a pressure transmitter ST700, Honeywell, the range of the instrument goes from 0 to 500 PSIA {SEE IMAGE ATTACHED}, the pump associated to the pressure trasnmitter is located in the suction line of this pump, Q iqual to 170 m3/h, H iqual to 56.3 m. in the suction line there is also a local manometer that shows 2inHg [Vaccum], 0-30 psig [pressure].
what I want to konow is the following
This pressure transmitter range is correct for my aplication, I think is ok, because the range instrumente covers 0 PSIA THAT IS -14.7 psig to 500 PSIA [485.3 psig], with my HART I CAN CONFIGURE THE INSTRUMENT IN A RANGE THAT I CAN SET IN THE RANGE FOR EXAMPLE OF 0 PSIA TO 50 PSIA THAT INSIDE THIS RANGE THE INSTRUMENT IS GOING TO WORK, SENDING THE ANALOGIC SIGNAL [4-20mA].
THE TECHNICHIAN SAID THAT THE PUMP CREATES TOO MUCH VACUUM AND DAMAGE THE DIAPHRAM OF THE PRESSURE TRANSMITTER, I DONT THINK SO.
I AM NOT A INSTRUMENT ENGINEER, BUT RIGTH NOW IS MY JOB.
PLEASE HELP ME.
IF I SAID SOMETHING WRONG PLEASE CORRECT.
THANK YOU SO MUCH FOR YOUR TIME
PLEASE HELP ME.
