High Alloy Base Metal Dilution in GTAW Fillets
We are joining Inconel 690 to 304L SS with a 1/8" fillet weld, performed by manual GTAW.
How much dilution can I reasonably expect? I want to keep it low, under 35%.
My initial guess would be 40%, but of course with manual GTAW much depends on technique.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
RE: High Alloy Base Metal Dilution in GTAW Fillets
https://nickelinstitute.org/~/Media/Files/Technica...
I've done the Schaeffler math so I know where we need to be. I just don't know what to expect for dilution.
My strategy is this: instead of going the higher alloy route (the conventional strategy), I would like to try and make ER312 work from below. At 30% dilution I calculate about a 28Cr-20Ni stainless deposit with around 6% ferrite.
The high alloy route means 52M and I don't need to tell you how grief-prone that is.
https://www.tandfonline.com/doi/abs/10.1179/136217...
http://be.linkedin.com/in/fusionpoint
Do you actually understand what dilution is ?
Probably good idea you do a bit of reading first and learn before commenting and making a very basic mistake.
Please enlighten me what's wrong with this method?
Dilution of the fillet weld deposit will be maximum at the root. I would suggest a mock up of the actual fillet be made and after depositing the root pass take a chemical analysis of the deposit. With proper arc positioning and selected current you should be able to minimize dillution from the 690 alloy and maximize dillution from the 304L.
However, apparently I'm wrong, but I'd really appreciate somebody pointing me to where I'm mistaking.
My apologies - my response was a bit harsh.
My comment was based on dissimilar metal welding and the resultant chemical composition induced by dilution.
Maybe I am the one who needs to do more reading.
Shane
However your last reply still confuses me.
Even with DMW, using the calculated dilution (based on surface area of both base materials / total molten zone), this still gives you a rather exact indication of the chemical composition. Do you suggest otherwise?
Again, taking into account the loss of some elements (I should have the list here somewhere), but you should arrive within a few % of reality.
I'd say that's good enough for doing the Schaeffler/De Long/WRC20/Bystram math.
'Welding development' is not R&D, it is trying to efficiently reproduce what 1,000 people before me have learned - I'm trying to ask one of those 1,000 people.
And for this case, a ferrite scope (or even a magnet) would be the best quick and dirty way to assess the composition and obtain proof of principle, and generating a little ferrite is my initial hope/objective.
With GTAW we have readily met less than 20% dilution, manually applied. With automated systems we have seen dilution very near 5%.
https://www.google.ca/url?sa=t&rct=j&q=&am...
I may be getting myself confused.
This is an excerpt from metengrs link regarding DMW.
"In fusion welding, the weld metal is a
mixture of the two metals being joined and
the filler metal. In arc welds made with
consumable electrode processes such as
SMAW, GMAW, SAW, and FCAW, the
weld metal is well mixed or stirred by the
arc action and the composition is quite uni-
form from one area to another. By sampling
any place in the weld
bead, the weld com-
position is determined and weld properties
reasonably predicted."
GTAW is not listed above so it is possible the weld deposit will not have a uniform composition in all locations.
How then will a macro show the approximate chemical composition of the weld deposit based on surface area ?
I am not looking to argue - just to learn a bit more about dilution.
It's an ongoing struggle to align my opinions with facts
Left to their own devices and preferences, welders may weld with too high amps and slower travel speeds than appropriate.
It was me that took the post off on a tangent and for that I apologise.
I made an inappropriate comment and then spent subsequent posts trying to withdraw my foot from my mouth.
I am still confused but will now stay well away from metallurgical posts,
Cheers,
Shane
Unless the base metal is very thin, I would start with an assumption that 15% of the weld chemistry comes from the nickel base metal, 15% from the stainless base metal, and the balance from the filler metal you select.
Nickel promotes austenite while chrome promotes ferrite. A common target for dissimilar base metals composed of carbon steels and austenitic stainless steel is 18% chrome and 8% nickel (minimum values) and a ferrite number between 3 to 10, 3 being the low and 10 being the high. Too much ferrite will promote Sigma phase, but if this is limited to a single pass fillet weld, it should not be an issue.
The Nickel Development Institute out of Toronto has a wealth of information on this subject. It may be worthwhile to review their literature.
Best regards - Al
I initially used just Schaeffler, which is more quick & dirty. Results were borderline, which is why I came here seeking hard experience.
I took your suggestion and plotted it on WRC-1992, and I was pleasantly surprised to find the predictions are significantly more favourable in terms of crack-resisting FN. However I did have to extend the isoferrite lines to cover the territory around about 28% Cr and 20% Ni.
30% dilution (15+15) predicts around 15% ferrite (higher than I normally would like).
40% dilution (20+20) predicts around 6% ferrite - just right.
So ER312 seems like a safe approach. Next step - find a way to get this tested at no cost to me
Best regards - Al
That is true, but I would estimate the error in my assumptions of compositions of the contributing alloys, variability due to welding conditions, and scatter inherent in the WRC-1992 diagram to each be greater. Of course dilution will always be the biggest variable.
