Unit Change - Defaults
ryandias
Automotive
CA
Is there a way to change the Units default values *(KG to Gram)?
I want the default to be changed?
Depends on what version of SE you are using. For ST10, the Units can be changed from MKS(meter,kilogram,second) to CGS(centimeter,gram,second) under Solid Edge options which is accessed from the Settings menu under the main pull down in the upper LH corner of the SE interface.
