API 653 / 650 Nozzle Local Discontinuity Code Allowable
I have a question regarding API 653 / API 650 that I was hoping someone may be kind enough to answer.
With regard to the maximum allowable stress at shell penetrations, is there any up rating factor over and above the stresses listed from table 4.1 of the code?
I am working a stress analysis of a storage tank and was thinking that there may be some allowed increase for nozzle penetrations etc. similar to the 1.5S, 3S system used under ASME VIII div 2.
It seems nearly impossible to have manways etc. by using the API 653 listed stresses from table 4.1
Thanks.
RE: API 653 / 650 Nozzle Local Discontinuity Code Allowable
Nozzle reinforcement is based on area-replacement methods, and it would generally be assumed that actual peak stresses might be substantially higher than the average allowable stresses. If the nozzle reinforcement complies with the code requirement, there is no code limitation on the actual stresses that can occur.
Similar issues arise at the chime area (for example, a plastic hinge in the floor plate is assumed, but plastic hinge obviously exceeds the allowable stress).
Annex P of API-650 addresses this somewhat with regard to external loading on nozzles.
Thanks for the response.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
White Paper - The Criticality of the E/E Architecture
Modern vehicles are highly sophisticated systems incorporating electrical, electronic, software and mechanical components. Mechanical systems are giving way to advanced software and electronic devices, driving automakers to innovate and differentiate their vehicles via the electric and electronic (E/E) architecture. As the pace of change accelerates, automotive companies need to evolve their development processes to deliver and maximize the value of these architectures. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
