Peening of very small Machine Screw Threads -- Effective?
I have encountered this requirement in a tech spec for an NPSM threaded fitting having 3/8" OD and machined threads.
I am initially dubious about the effectiveness of thread peening, since the spec writers are world class overkillers. But having no experience with the practice I thought I would throw it out to the Eng-tips fastener experts for comment.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
RE: Peening of very small Machine Screw Threads -- Effective?
NPSM can be rolled.
There is a shoulder at one end of the part that precludes rolling. Which leaves only inferior cutting.
What is the material, and what is the environment ?
Is it possible fatigue cracking is a concern? Perhaps because a heavy gauge is going to be mounted on a long pipe spud, inviting a nive low "reed" frequency ?
In some industries Shot peening threads has a good reputation for reducing galling tendencies.
"So, for oilfield tubular connections, both the cut and rolled threads require a final surface modification treatment of controlled shot peening."
http://www.mfn.li/article/?id=390
Fatigue is not a concern.
The joint is expected to be connected once only during the lifetime, so is galling much of a concern?
Glass beads come in small sizes and can be used to peen threads, small features and delicate parts.
Is this a tapered pipe thread, or a straight pipe thread?
Either way, If truly unlubricated assembly, Galling at assembly can ruin your day.
If tapered, a liquid tight seal is expected, so teflon tape or pipe dope will be applied at assembly. Both have powerful lubricating effects.
Note the low galling resistance of unlubricated 304 against some materials in Table XI here -
https://www.nickelinstitute.org/~/Media/Files/Tech...
This 1979 report has some tests of 304 fasteners and "heat treated" Inconel.
http://www.iaea.org/inis/collection/NCLCollectionS...
The parts were pretty aggressively degreased.
In Table 1 it looks to me like 304 on Inconel either tightens unscathed ( Visual 1) or goes to hell ( visual 4 and 5 ) .
If truly assembled unlubricated, then the galling resistance of peening suggested by the previous link to oilfield practice makes sense to me.
Section 3-3 here -
https://www.shotpeener.com/library/pdf/2001012.pdf
Straight thread, NPSM per ASME B1.20.1. Actual thread height is only about 0.036".
