Contact US
proximitor VS Velocimeter on a Turbomachinery
Hy guys,
i'0m talking about 45 MW turbomachinery and i'm tring to decide the best installation for vibration sensors on all components.
Because i found lot of discussion about, i'd like to know your opinion about this question:
  • pickup shaft movements with proximitor (#2@45° on vertical line or other solution) or take vibrations from bearing-cap velocimeter?
I't is clear that both should be the best but consider possibility to install once, what do you will choose and why?
RE: proximitor VS Velocimeter on a Turbomachinery
If machine has journal bearings with holes in bearing housings for proximity probes, is already installed or about to be, and does not have proximity probes installed, then install proximity probes. Otherwise install accelerometer/velocity sensors on bearing housing. Obviously sensors on bearing housing are easier to install with less expense, but may not provide adequate vibration data; depending on requirements. You should clearly state your requirements!
Walt
Yes Strong,
the question is, with this two type of sensors which one provide more exhaustive data information of a machinery problems can occur?
Select Proximity probe for journal bearings.
Walt
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
