Locating Pins - C-1144 Black Oxide vs 440C Black Oxide
I'm looking to have some diamond nose locating pins made. These pins will be aligning two anodized aluminum parts. Besides corrosion resistance we are also concerned with a shear fracture, due to the brittle material.
I'm wondering if C-1144 with black oxide finish would be sufficient or if 440C stainless with black oxide finish would be worth doing.
The quote I received said they can get a Rockwell hardness of RC 60-64 for the C-1144 and RC 56-60 for the 440C.
Thanks for any suggestions you can give me.
RE: Locating Pins - C-1144 Black Oxide vs 440C Black Oxide
If they're just aligning, why are they carrying load? Aluminum will plastically deform long before such a hard pin shears. Black oxide coated 1144 steel will only temporarily resist athmospheric corrosion.
They're aligning and carrying some load as well. There's a Clampco V-band clamp holding the two mounting flanges together, so some of the load is carried by the clamp.
I was thinking about the 440C, but another engineer here is concerned about the tensile strength vs. the C1144 after hardening.
As TBE said, the 440C is still three times as strong as the Al that it will be mated to.
If you want some corrosion resistance then go with the 440C.
Sounds good. Thanks, guys!
I believe that black oxide is porous and requires oiling to actually provide much corrosion protection.
Yes, our pins are heavily greased before assembly.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
White Paper - Medical Device Design Control
Medical device product development is a highly integrated and regulated process. Implementation of a requirements tracking solution requires attention to a variety of nuanced topics. When presented with the task of tracking the many concept relationships in a project of this type, the initial software solution of choice tends to be a two-dimensional text systems. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
