Problem with geometric pattern
lorenzomilani
IT
Hello everyone, it's the first tutorial with Creo Parametric 5, for the exact I'm following this :
Link
I can successfully do only the first pattern with reference to the axis and using the original non-mirrored rib feature.
I always failed the pattern of mirrored speck, and n the wireframe preview that shows me when I failed, the last element of the pattern mysteriously it is not displayed ( it should be 7 and not 6. in pattern setting I put elements 7 and angle 360/7)
Thanks so much
 https://files.engineering.com/getfile.aspx?folder=d023890a-422e-4cc5-94b6-368363585eb5&file=turbina.prt.zip
