Maximum Length of wood shear on Overturning forces calculations
Hey all,
Is there any limitation on the length of wall that could be utilized for overturning/holddown capacities calculation on wood shear walls? For example, if the shear wall is 50' long , would it be effective to take the full length of shear wall to calculate tension or compression forces to determine hold down requirement. I am not aware if there is any limitation for the length of shear wall to calculate chord forces at end per NDS? Personally, i think the use of 50' length for overturning calcs will be ineffective on wood shear walls. I will appreciate any suggestion.
RE: Maximum Length of wood shear on Overturning forces calculations
I don't have a definitive answer for you but I share the concern. I see this with unit demising walls a lot where they get quite long. I also wonder about unintended joints in shear walls. Often, when walls are prefabricated, I find that demising walls end up getting fabricated and shipped in as many as three or four pieces. You can stitch the segments together with fasteners easily enough but, at some point, I'd have to think that there would be performance penalties.
I find it a bit comforting to thing of wood shear walls not as giant rigid bodies but, rather, as rigid individual sheets of sheathing, each racking/rotating about it's own center of gravity. There is some validity to that model I believe and it gets me a bit closer to believing in long shear walls.
If you are concerned, then look to the code diaphragm limitations of 3.5 or 4 to 1. Provide additional hold downs at these locatons to break up the wall.
Mike McCann, PE, SE (WA)
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
eBook - Managing the Context of Product Complexity Using the Digital Twin
Keeping track of changes to complex products is difficult—think Aerospace & Defense equipment, new generations of commercial aircraft, and software-based automobiles. A new way to managing the digital context of the physical product is required and the answer is the Digital Twin. This ebook explores the opportunity available for Operations and Maintenance for the Digital Twin. Download Now
White Paper - Trends in Industrial Filtration
Substantial progress has been made in filtration technologies in recent years. New filter media materials, designs and processes have led to filters that are more efficient, reliable, compact and longer lasting. This white paper will discuss the various trends that are impacting operational responsibilities of MROs today and the resources that are available for staying up-to-date on the latest filtration solutions. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
