Error message in Strand7 - Rotation at node is too large.
Hi, I am trying to run a nonlinear analysis on a suspension tower only with its own weight. I have fixed all four feet, both rotational and translational. I get the message "ERROR[ 13]:Solution has diverged. Rotation at node 157 (3.4884E+08 deg) is too large. "
I have tried to fix them, but then I get other nodes with the same message.
Does anyone here have any tips to how I can solve this?
Thanks!
RE: Error message in Strand7 - Rotation at node is too large.
Good to see a Strand7 question. It is tricky to say, because it says that the node is rotating too much.if you attach your model , I can have a quick look for you. Otherwise check restraints, units, material properties, and that freedom cases is active/ticked in the load increment section of the nonlinear solver.
If you have current Strand7 support, contact them, with a copy of your model.
If not, post the model here, after checking the things listed by Erik.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
A very common cause of this issue is that people model a truss structure, applying three rotational releases to both ends of every truss member (to simulate pins and torsional release at both ends of the member). This leads to one or more nodes not being rotationally "attached" to anything, so the solution will fail. Try making sure that every truss member is torsionally "fixed" at at least one end, if not both.
http://julianh72.blogspot.com
Thank you so much for your answers. After some hours, I finally found out what was wrong. I ran a linear analysis and looked at the deflections. I found out that I introduced two nodes and forgot to intersect the beams to those nodes...a little embarrassing dazed
Great to see a lot of interest. All answers, are very relevant. Many truss elements representing a member will behave like a chain/cable not having any stiffness in compression, so that could have been a problem. This is is not a problem for beams since they have rotational degrees of freedom, and stiffness. So for trusses there should be one element per member, unless we are modelling a cable (GNL, and pretension is needed for lateral stability,which can be switched off once lateral stiffness develops). Also great idea to run LSA, and see how the structure behaves.
Always a good idea to clean the mesh before a run!
Doug Jenkins
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
