Manual 3-way Valve
Manual 3-way Valve
I am hoping someone can help me with this. An application calls for a manual 3-way valve where when the lever is in the center, there is no flow to either of the two outlet ports; when lever is turned from center, flow will go through one of the outlet ports (lets call this south); turned the other way from center, flow to the other outlet port (lets call north). The application also wants to know which outlet port is flowing. So let's say we use two (2) position switches where:
Does anyone have suggestions to prevent these problems from occurring, even if it means I have to go a totally different route?
- both contacts open = lever is in center position (i.e. no flow through either outlet port)
- one of two switches contact is open while other is closed = lever is turned away from center (i.e. flow to south outlet port)
- other contact open while second contact is closed = lever is turned away from center (i.e. flow to north outlet port)
RE: Manual 3-way Valve
Two single valves will probably be less expensive also.
- block
- north
- south
NorthNOT AND SouthNOT = block
I agree with George and Roy, two valves and some logic.
