I am curious to hear some of your opinions on this, and at the very least....vent a little bit. I am talking primarily about residential work here, but it is certainly not uncommon for a contractor to do something a little bit different than I intended. Surprise surprise. And I typically evaluate what was done, provide a "fix" if one is needed and move on. I don't always enjoy doing it, and would prefer that if they are going to change something that it be discussed BEFORE the work is done. But such is life, and I've earned quite a few clients and recommendations by being responsive and easy to work with so long as the job gets done in structurally satisfactory manner. I typically charge extra for any extra work that is done. My question is this: Do you think you have an obligation to see a project through when the plans are completely ignored? Do I have an obligation to help them out of the mess they create by not following plans?
The reason I ask is: I don't mind when its something here or there, but when it becomes clear that the plans were thrown away, completely ignored and done the way they wanted to, my patience grows thin. The only reason I know about any of it is because they got "caught" at inspection time and need me to write a "paper" (contractor's words) saying its okay. Analyzing, trying to justify, and trying to come up with feasible repairs for jackleg work isn't on my list of favorite things and is honestly a bigger/harder job than the original design! Obviously I wouldn't do this for free, but I just flat don't want to do it at all. I wouldn't even consider taking on the project if I weren't already the EOR. I don't want to jump through hoops because of their blatant disregard for the plans. I could fix a house that a blind monkey built, but that doesn't mean I want to! Do I have to? At what point do you say, "you clearly show no intention of following my direction, so go find someone else to help you with this additional work - I decline to provide a proposal for this additional work."?
Like I said, I have always found a way to correct, move on and work with the contractor. I have a lot of respect for many of the contractors I work with, but this guy.....I've had it. I wish I had a way of knowing who the contractor is before accepting a project. I hate my name being on a project that is built by some of these people. It is days like this that I want to start a design-build company and only work on things that get built right. "If it is worth doing, it is worth doing right"!
Thanks! I am curious to hear your opinions and advice.
