Cement-Bentonite Slurry
Has anybody experience placing CB slurries underwater using a tremie method. I have experience tremie concreting of large steel pipe piles, placing structural concrete but not CB Slurry. I am interested to know if CB slurries could be placed by a tremie in 10 m deep casings (1 m dia)that contain about 5 m of groundwater. My question stems from ather low density of CB slurries if they could provide a front to push water upwards without mixing with water. Thank you in advance.
RE: Cement-Bentonite Slurry
It has already been done, in my case replace bentonite slurry by BC slurry in a slurry wall 50 deep and 1 m wide. You must be sure that your CB slurry is stable which means good hydratation of mother bentonite slurry and enough cement ( around 180 to 200 kg per m3).Obviously you will get, just like with concrete, some "bad" CB slurry/water mix on top.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
