Contact US
GTAW Pulse Frequency
I'm reviewing a WPS for auto GTAW used to make fillet seal welds in heat exchangers on 0.5" Ø nickel alloy tubes.
It uses the following parameters:
Root pass
Peak: 62A, 0.1s dwell
Low: 40A, 0.1s dwell
Travel speed 4.3 ipm
The subsequent passes have 1/3 higher peak current and with the same low current and dwell times, which amount to 5 cps.
My question is this:
At 5 cps, does pulsing actually provide an advantage compared with constant current of the same mean value? The frequency seems quite high compared to what I am more familiar with in heavier wall pipe welding applications.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
RE: GTAW Pulse Frequency
Increased penetration from the higher peak amperage, better control over bead shape/profile/width (especially in sluggish materials).
I understand how it works, I'm just not convinced that 5 cps is slow enough to obtain the desired effect.
Higher PPS also tends to constrict/focus/stiffen the arc so it doesn't wander and can make a slightly narrower weld.
ASW Welding Handbook VOL-2 Recommendations:- The GTAW process generally ranges from 2 seconds per pulse to 10 pulses per second, with the lower frequencies most commonly recommended. This comes to 30 pulses/min to as high as 600 pulses /min. Typically lower pulses would work better for seal welding of 0.5" Ø nickel alloy tubes.Higher pulses under present context may just cause burn through, which is better recommended for thicker walled weld joints.
Pradip Goswami,P.Eng.IWE
Welding & Metallurgical Specialist
ca.linkedin.com/pub/pradip-goswami/5/985/299
We weld thin stainless with 5-10kHz pulse, it all depends on the application.
Given the multiple effects of pulsing I see no reason to question this pulse rate.
OK, between these answers and some intensive research I've learned what I need to know.
Thanks to all.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
