Hi guys,
I am new in this forum, but I often follow it and found very interesting information.
I have this situation on the Al. floor channels structure when the surface protection is not well defined and is not clear if is need to paint inside fasteners holes.
Both holes are drilled at H11, CSK on the bolt side.
Both Al channels are SAA+ Primer+Topcoat at detail stage, holes are drilled afterwards at final size at assembly.
Bolt Ti 6Al-4V, with SAA
Anchor Nut floating, CRES, passivated.
The bolt is wet installed with sealant.
The question is, after drilling the full size holes and expose the Al. substrate, what kind of protection is needed inside of the hole from corrosion point of view?
When using Primer+Topcoat, as there is no good control of the layer thickness, sometimes the hole is too small to insert the fastener. Personally I think only primer will be good enough.
