Slip-critical connection design: Minimum and maximum bolt pretension
Table J3.1 in AISC 13th Edition gives the minimum bolt pretension values (148 kips for a 1.5 inch A490 bolt). I have to design a slip-critical connection using equation J3-4. Can I use a higher value for bolt pretension (160 kips) in this equation? Does AISC specify the maximum bolt pretension value for bolts?
I am using a slotted hole (hole length= 2.625 inch). As per AISC the hole factor for a short slotted hole (hole length is 1.875 inch for 1.5 inch bolt) is 0.85 and for a long slotted hole (hole length is 3.750 inch for 1.5 inch bolt) is 0.70. Can I use the linearly interpolated hole factor of 0.79 for hole length of 2.625 inch?
Su
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Criticality of the E/E Architecture
Modern vehicles are highly sophisticated systems incorporating electrical, electronic, software and mechanical components. Mechanical systems are giving way to advanced software and electronic devices, driving automakers to innovate and differentiate their vehicles via the electric and electronic (E/E) architecture. As the pace of change accelerates, automotive companies need to evolve their development processes to deliver and maximize the value of these architectures. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
Modern cars, trucks, and other vehicles feature an ever-increasing number of sophisticated electrical and electronic features, placing a larger burden on the wiring harness that enables these new features. As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - Modeling and Optimizing Wire Harness Costs for Variation Complexity
This paper will focus on the quantification of the complexity related costs in harness variations in order to model them, allowing automated algorithms to optimize for these costs. A number of real world examples will be provided as well. Since no two businesses are alike, it is the aim of this paper to provide the foundational knowledge and methodology so the reader can assess their own business to model how variation complexity costs affect their business. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
