From automatic control theory involving Laplace blocks, I can see that the two systems (drawn in the figure) are 'equivalent'.
However, the lower figure with the pure integrator at the input becomes a practical problem, or something that is not practical or workable, right? My thinking is that the 1/s block is a pure integrator, so if the input signal is a constant value, then the output of the integrator just keeps getting larger and larger indefinitely, right? So if this were to be done with a real-world system, then this wouldn't work, right? Thanks all!
The problem with Laplace transforms is that they ignore the limitations of electrical hardware.
The first diagram could be a model of a motor in position mode.
The second diagram would work as long as the output of the first integrator wasn't allow to integrate up to the limits of the power supply or some other limiting factor. For instance a sine wave could be the input that has an offset of 0. Both should work the same way as long as the sine wave had an offset of 0 and the amplitude was not big enough to cause the power supply voltage limitations to be reached.
So the two are equivalent but with different input restrictions.
Integrators typically need to have both an initial condition and max/min saturation conditions applied when used for modeling and simulation or control purposes.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
RE: Laplace integrator at input of system - expected issue?
PN and XN ...... thanks for your time and kind help!! Totally appreciated. This really helped a lot, as I was thinking about equivalent diagrams..... and noticed some possible issue with applying the lower diagram.
The note about hardware limitations and integrator at the input was really good.
Thanks again.
Thank you for helping keep Eng-Tips Forums free from inappropriate posts. The Eng-Tips staff will check this out and take appropriate action.
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Metal 3D printing has rapidly emerged as a key technology in modern design and manufacturing, so it’s critical educational institutions include it in their curricula to avoid leaving students at a disadvantage as they enter the workforce. Download Now
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Peter Nachtwey
Delta Computer Systems
http://www.deltamotion.com
http://forum.deltamotion.com/
xnuke
Thanks again.
