non convergence for nonlinear analysis
Hello everyone,
I have simulated nonlinear characteristics of sandwich composite subjected to three points bending. But I have theses two questions.
1) how to solve this problem that is numerical singularities at one node. Besides, this warming seem on effect other iterations, how come?
2) how to solve this question which are 8 negative eigenvalues. Besides, the error is show that too many attempts made for this increment. I cannot sure whether the negative eigenvalues cause this error.
RE: non convergence for nonlinear analysis
A singularity usually indicates a possible rigid body motion of the part in the mentioned DOF. If it is at the beginning and it disappears, then it probably was a open contact state.
Negative eigenvalue are usually caused by a loss of stiffness or solution uniqueness, either in the form of a material instability or the application of loading beyond a bifurcation point (buckling). When the analysis converges in further iteration and the results look plausible, then they can be ignored.
You should not only look at the messages, but also what is happening in the equilibrium calculations (Residuals tab). How to read that is explained in the 'Nonlinearity' section of the Getting Started Manual.
Sincerely thank you @Mustaine3 for your kind help.
White Paper: Rapid Manufacturing with FDM
The automotive industry is increasingly turning to additive manufacturing, and fused deposition modeling (FDM) specifically, as a reliable alternative to traditional metal-cutting methods, like milling, turning and boring. Download Now
White Paper: Revolution in Design
Open up new possibilities for your business by changing the way you think about product development. Compared to traditional methods, 3D printing offers advantages that allow you to make more innovative products and get them to market faster. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
