Dear all,
in one of my companies material specifications for pressure vessels I found a requirement for ASTM A 387 Gr. 5 having a J-Factor <150.
I am well aware of the susceptibility of Gr 11 and Gr 22 in high temperature service to temper embrittlement but could not find any document mentioning the same behaviour for 5%Cr-Mo steel.
Have you encountered similar requirements or are you aware of a technical basis for limiting the analysis?
Thanks for your help
Daniel Breyer
Inspection Engineer
Daniel Breyer
Inspection Engineer
