Contact definitions: shell to shell & shell to solid.
Hello everyone,
I want to model the following case and I use LS-DYNA for my simulation:
1) Two cylinders made of shell elements have to be connected by the edges. They have the same diameter, but are made of different materials. I tried TIED_SURFACE_TO_SURFACE, but they seem not to be tied.
2) There is a ring inside the cylinders. Its made of solids and the offset between the ring and the cylinder is half the thickness of the shell elements (5 mm). For this I have chosen TIED_SURFACE_TO_SURFACE_OFFSET, but unfortunately I have initial penetrations, which are quite big. Only reducing the contact thickness by 50% (which is by default the shell thickness) has lead to a significant reduction of the initial penetration. Still 50% seem very big.
Has anyone any experience or idea how to handle this two problems? I am helpfull for any advice! The meshes are very fine btw., so I do not think the problem can be solved by a further refined mesh.
Many thanks in Advance and have a nice day!
Ed93
Here is a piceture of the problem. The diamater of the cylinders is 350 mm. The outer diameter of the ring is 345 mm, so the gap betweens the shells and solids is 2.5 mm. The shell thickness is 5 mm.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The New World of Thermoplastic Manufacturing
Digital-direct thermoplastic manufacturing offers exceptional quality, opens the door to novel design parameters not possible with injection molding while also bypassing the long lead time and up-front investment in injection molding tooling, offering a better total value proposition. Download Now
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
