Total Heat Flux or Total current through a section??
I am solving a Electric Thermal coupled analysis. Here i want the total current passing through a conductor. In the output requests all i get is electric current density and ECDA which seem like nodal properties. Is there a way to get the total current(Heatflux) passing through a section ??
RE: Total Heat Flux or Total current through a section??
Thank you for your response.
The outputs i have are ECD (electric current density ) and the other one is ECDA (Electric current density multiplied by area).
Am i supposed to sum the ECDA values for the nodes lying on the section??
The input current was 100A
Summed total ECDA is 4400A
I must be doing something wrong.
https://files.engineering.com/getfile.aspx?folder=...
Please have a look into the XY plots attached.
Thank you
