ADAMS FULL VEHICLE SIMULATION ERROR
I am stuck on this error in adams car while performing full vehicle simulation can please help to fix it.
---- START: ERROR ----
Static equilibrium analysis has not been successful.
The maximum number of iterations 25, has been reached.
For the last attempted iteration:
The equation with the largest error was model.NEW.ges_frame Comp = 8 Error
= 209292.647786
The variable receiving the largest increment was
model.TR_Front_Suspension.jolcyl_lwr_upr_strut Comp = 2 Delta =
137135.249593.
---- END: ERROR ----
Static Solution failed to converge
End Static Solution
Simulate status=-124
acar_2016.0.0/vdm::apre_fvbcsb
**** Error:
Sim/stat cannot be achieved.
Aborting Execution.
Adams Solver (C++) run terminating due to STOP requested by user.
Termination status=-995
Terminating Adams Car usersubs...
Finished -----
Elapsed time = 1.22s, CPU time = 1.20s, 98.46%
Simulation is complete.
ref:_00D306wqz._5000c1aEiCa:ref
= 209292.647786
137135.249593.
End Static Solution
**** Error:
Aborting Execution.
Finished -----
RE: ADAMS FULL VEHICLE SIMULATION ERROR
I suspect you are using the demo vehicle model. You have probably changed something. Change it back and see if the problem goes away.
You can change MAXIT or use a static funnel.
Basically, you have given me 200 bytes of text to deduce what is wrong with a 1 Mbyte model. Not going to happen.
Cheers
Greg Locock
them. I will try to make new one.
Thanks for your help I will definitly try
MAXIT and static funnel
Thank you
Thank you very much
