Contact US
HTRI Shell & Tube Heat Exchanger setting plan. Saddles location
For HTRI setting plan ouput, what is the basis of location of saddles for Xist design of Horizontal Shell & Tube Heat Exchangers.
RE: HTRI Shell & Tube Heat Exchanger setting plan. Saddles location
Request response from experts.
Varies depending on code requirements and TEMA class, so a combination of the two. It does an estimated weight calculation which is detailed in the design manual, which I assume is used for the location of the saddles.
HTRI is not a mechanical design program. HTRI program is focused on the thermal and hydraulic modeling of heat exchangers. HTRI does not have the option for seismic and/or wind loading. Saddles are not "designed" in the program and the estimated saddle locations is just that, an estimation. HTRI attempts to locate the saddles with adequate clearance to the process nozzles, but that also can be incorrect if the nozzles require reinforcement pads, since HTRI does not model/calculate nozzle design on the shell.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
