FEMAP API Woes - Element.GetGeomPropArray usage
Hello Group.
I'm new to API usage/programming (and not much of a programmer in general), but have been trying to "Frankenstein" via examples a script that takes a selected group of elements, provides centroid coordinates and mass of each element, and essentially writes to a file a point cloud of element data that can be manipulated in Excel to generate distributed and cumulative axial and radial mass distributions for the selected element group. (Eventually I would like to perform the Excel operations in the script (sorting by coordinate bands, summing for each band, etc.), but first things first....).
Program is below. Note, for general information only, Z-direction is along FEM centerline, X and Y are transverse. I could make these variable, but for now plan to routinely set FEM up this way.
Things were going just fine until I added the "Dim mt" and "Set mt" definitions such that I could pull density for a named material and output that for the elements in a listing rather than just the material. (Actually, I later want to multiply that density by the element volume to produce an element mass value.) After that change, the Element.GetGeomPropArray operation seemed to product no meaningful information. Null (?) For example, after printing the numelem variable, the program returns "0". Program runs to completion without error messages in this case, but no output. And attempts to print other Element.GetGeomPropArray returned variables produces an error message regarding the variable.
Comment out the "Dim mt" and "Set mt" and respective operations, and remove rho from print request, and I get printed data for selected elements as expected.
I'm sure I am missing something very fundamental, but have spend hours trying to resolve. First resort is usually to do my best to work problem out for myself. Now becoming desperate.... winky smile
Any input would very much appreciated!
JD
Sub Main
Dim App As femap.model
Set App = feFemap()
Dim mt As femap.Matl
Set mt = App.feMatl
Dim Element As femap.Elem
Set Element = App.feElem
Dim elSet As femap.Set
Set elSet = App.feSet
Dim fName As String
Dim setID As Long
Dim numElem As Long
Dim entID As Variant
Dim propID As Variant
Dim matlID As Variant
Dim elemTYPE As Variant
Dim topology As Variant
Dim vCG As Variant
Dim vAXIAL As Double
Dim vRADIAL As Double
Dim length As Variant
Dim area As Variant
Dim volume As Variant
Dim rho As Double
Dim matNum As Variant
If App.feFileGetName( "Select File to Write Data To", "Text File (*.txt)", "*.txt", False, fName ) = FE_OK Then
Open fName For Output As #1
Print #1, "Element_ID " & " axial_distance " & " radial_distance " & " el_volume " & " material " & " density "
setID = 1
Element.setID=elSet.Select(FT_ELEM, True, "Select Elements to Include in Mass Distribution" )
Element.GetGeomPropArray(setID, numElem, entID, propID, matlID, elemTYPE, topology, vCG, length, area, volume)
REM Test Print
Print #1, numElem
For i = 0 To numElem - 1
vAXIAL=vCG(3*i+2)
vRADIAL=((vCG(3*i)^2)+(vCG(3*i+1)^2))^0.5
matNum = matlID(i)
mt.Get(matNum)
rho = mt.mval(49)
Print #1, entID(i) & " " & vAXIAL & " " & vRADIAL & " " & volume(i) & " " & matlID(i)& " " & rho
Next
Close #1
End If
End Sub
RE: FEMAP API Woes - Element.GetGeomPropArray usage
Fix from other forum
https://community.plm.automation.siemens.com/t5/CA... :
Try this. You aren't that far off, but there were a few issues. First, most API calls return a return code...that should be tested for FE_OK..or some failure code, but not set into an ID like you had for the elSet.Select call. Secondly, and more importantly when an API call asks for the ID of a Set, you should always use SetObject.ID... in your case elSet.ID. You were passing the variable "setID" which you hard-coded to 1. I think that it just happened to work in your case before adding the "Dim mt...." code because elSet.ID must have been equal to 1. After you added that, it must have been something else and you weren't checking the elements you thought you were. Hope this helps.
The HTML Clipboard
Sub Main
Set App = feFemap()
Set mt = App.feMatl
Dim fName As String
Dim numElem As Long
Dim vCG As Variant
Dim area As Variant
Dim rho As Double
If elSet.Select(FT_ELEM, True, "Select Elements to Include in Mass Distribution" ) = FE_OK Then
If Element.GetGeomPropArray( elSet.ID, numElem, entID, propID, matlID, elemTYPE, topology, vCG, length, area, volume) Then
Print #1, numElem
vAXIAL=vCG(3*i+2)
matNum = matlID(i)
If mt.Get(matNum) = FE_OK Then
rho = mt.mval(49)
Else
rho = 0.0
End If
Next
End If
End If
Close #1
End If
End Sub
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
