Contact US
DMS 1926 material when no type or class is specified?
Is there a way to get DMS specifications from Boeing? I have access to MyBoeingFleet and get BMS specs all the time, but they don't provide DMS specs as far as I can tell. The only Long Beach document they provide is the DPM Index which has a QPL for the DMS, but nothing else.
My issue is the drawing I'm using to repair a panel lists DMS 1926, but gives no type or class and I was hoping the spec would indicate what to use if no type or class is specified. based on the laminate thickness, .125 for 12 plies I was expecting the fabric is 1581/7781. It has one ply of Type 120 on the outer surface that it does specify by calling out the MIL-C-9084 cloth Type but nothing for the rest of the plies.
thanks,
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
RE: DMS 1926 material when no type or class is specified?
Is DMS1926 a composite material? cloth? Tape? dry? wet? prepreg?
Suggest asking this question in the composites forum...https://www.eng-tips.com/threadminder.cfm?pid=327
Regards, Wil Taylor
o Trust - But Verify!
Sorry, DMS 1926 is for 250° cure pre-preg fabric materials. I need it for a fiberglass panel, but the spec also includes Kevlar fabrics. I found an old copy of the DMS spec that had a cross reference to the equivalent BMS spec for the fiberglass materials. It doesn't have any direction for when no type or class is called out, but the panel isn't structural and I'm pretty sure the material is 1581/7781 based on appearance.
-Kirby
Kirby Wilkerson
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
