what is the impact or influance of
what is the impact or influance of changing the cooling fan on non -drive end shaft of an vertical electric motor of 225 kw power with another which is not the same and it make noise?
RE: what is the impact or influance of
Different cooling capacity and different noise level. You have not provided much information.
JHG
this motor was in overhaull inspection (mechaniccally and electrically) all tincks were inspected ,but the only thinh the fan was broken and replaced by another oversized because we haven't the original one, so this none orginal fan makes noise and high temperatures of bearings the both side ( increasing until 95°C we stopped it) of the vertical motor.vibration normal for motor & pump 0.9mm/s & 1.2mm/s , widdings T° NORMAL
MY QUESTIONS IS IF THIS INCREASING TEMPERATURE WAS FROM THE OVERSIZE FAN AND THE PROBLEMS THAT ACCOMPANY THIS CHOICE
thanks a lot.
If you replace an existing fan with a new, bigger one, I would expect different performance. Is the new expected to run at the same speed as the old one? I would expect the bigger fan use use more motor power. I would expect it to move more air, but is this air hitting your motor? If it isn't, I would expect increased temperature.
If you modify your cooling system and the temperature goes up, your modification does not work.
JHG
What "noise" are you referring to in your first post? If it's due to having more radial vibration, then your bearing loads would be higher.
Walt
I don't recall ever seeing a motor cooling fan that was not a simple radial device, so direction of rotation should not come into play regarding efficiency and noise.
Along the lines of what others said, if the fan has a back plate, and was installed backwards, it might be blocking off a lot of the cooling air flow.
I'd expect two or even three radial fans of similar diameters and number of blades to provide similar cooling performance. If that is what you have, I'd look elsewhere for the overheating.
I'd expect aluminum or plastic motor cooling fans to have little impact on overall motor balance/unbalance, and thus 1X vibration, if somehow that is related to the increased "noise."
If you provide a more thorough description of the characteristics of the "noise" I expect it will reduce the number of posts (itself a type of noise) substantially.
https://www.thefreedictionary.com/noise
