DoraeS
Petroleum
- Mar 8, 2004
- 44
If I have a vertical firewater overboard line with a vent on top of this vertical line, by applying Bernoulli equation between point 1 (on top) and point 2 (on exit at bottom):
P1 + rho.g.h + 0.5rho.v1^2 - friction = P2 + 0 (reference height) + 0.5rho.v2^2
suppose the height is long and v2 has reached its terminal velocity (due to gravity), such that
rho.g.h + 0.5rho.v1^2 - friction - 0.5rho.v2^2 > 0
with a properly sized vent, I can assume P1 = atmospheric.
Now one would assume P2 is also atmospheric since it is the discharge point of the overboard line. But the formula above suggest that P2 > P1 and is more than atmospheric.
Am I correct to say that P2 is larger than atmospheric at the point of exit, but once water exits, the pressure energy will convert to velocity energy and therefore the water flow velocity will be increased?
Thank you.
Thank you.
