Creo 2.0 on windows 10
sudhakarn
Automotive
IN
Hi folks,
I tried installing the creo 2.0 in windows 10.But it's not running when I launch the creo parametric icon.
Windows 10 64 bit,creo 2.0.Ssq patch.
Please let me know if you need any other details. This is a Student version downloaded from internet.
Request your support please.
Check the date code of the student edition. Only Creo 2 m190 or higher is supported on Windows 10.
Ben Loosli
Not sure if you're still figuring this out, but I've found that using Creo 2 M100 seems to launch and run ok on Windows 10, despite not being supported. However, interestingly, if you launch it using compatibility mode (Windows 7) it does not launch.
Thanks a lot for your insights looslib and superskiaholic.will check it out.
