Working with GM TCe print internally
Jashe
Automotive
When we release a print in GM TCe we have to over-write our internal print so we have the most recently updated print. But when I export it internally I cannot make any changes to anything that uses a macro (e.g. rev block, names, date). I can't use the macro if it's not GM TCe NX. Is there a way to make those changes?
GM Launch has options to start Teamcenter and also NX (native), unless you (or whomever did the installation/configuration) removed those options.
I don't see a "Native" option anywhere when I start TCe. I do know that when I option NX through TCe, I cannot open a file within our internal drive. Does that mean anything?
Please tell us how do you start GM Teamcenter.
Do you use GM Launch, or use something different?
We use GMLaunch 6.1. Sorry for the delay on this. Hope you get this response.
What options do you have in GMLaunch?
There should be a section called "CAD"
From there you can start NX "Native" without connecting to GM Teamcenter.
It does have an option called CAD but it doesn't do anything. There's also a tab that says CAD. But I didn't see any options for "Native" anywhere. Probably a licensing thing.
