Copy command copies entities to active layer even though "copy on active layer" is off 1
Michael Koenig
I came across the same issue described in thread1480-431555 and wanted to share the solution.
Disabling the following option resolved the issue.
Toolbox tab or pull down menu > Settings > Layers > Enable predefined layering
Cheers,
Michael
 https://files.engineering.com/getfile.aspx?folder=7cbe3f64-498a-4812-a397-afa83fccf991&file=Enable_predefined_layering.png
