Correct handling of tyre rolling resistances: Drive / Coast and 4WD
I'm (re)building a MATLAB simulation of longitudinal vehicle dynamics and want to sanity check my handling of tyre rolling resistance power losses:
For the Drive case (RWD), I am calculating front tyre rolling resistance losses (P = FV where F = CrrN) only and modelling rear tyre losses as Contact Patch Slip Speed x Contact Patch Longitudinal Force (P = FV).
For the Coast case, I calculate all 4 tyre rolling resistance losses.
For the Braking case, I model all 4 tyre losses as Contact Patch Slip Speed x Contact Patch Longitudinal Force (P = FV).
I am curious how this relates to coast-down tests used to derive road loads for emissions tests. These are obviously Coast condition with all 4 tyres contributing a rolling resistance loss. But if the derived road load is then used to set up a dyno, is the dyno road load not too high by the amount contributed by the driven axle? Or is this compensated for in some way.
And, for the Drive case for a 4WD, then presumably there is no contribution of rolling resistance from any tyre, just slip loss?
Thanks, Ian
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper – Data Security and Know-How Protection
Our data is constantly exposed to the danger of being intercepted or stolen as it wends its way over global data networks. Data security measures and measures for protecting intellectual property should not, however, first be implemented when data is exchanged – companies must lay the foundation for these measures within their own organization. Download Now
White Paper – Collaboration in the PLM Context
The influence exerted by the Internet of Things (IoT) means that there is a steadily growing need for collaboration in industry. Partners from new industries and areas of application need to be integrated in cross-company business processes to ensure that the lifecycle of smart, connected products can be managed from end to end. Download Now
White Paper – The Challenges of PLM Collaboration
There is cross-company collaboration - and then there is cross-company collaboration. Large-scale corporations and joint ventures need different mechanisms to protect intellectual property from those required for communication between different company locations with heterogeneous IT landscapes. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
