Which constraint should I use on my FEA?
Hello everyone!
I'm performing a finite element analysis with a pair of gears and another component around this pair of gears. This system is named as "planetary gears". My model is simplified, just to see how will be the behavior of the system, I'm using the software Hypermesh with the solver OptiStruct. My question is, which degrees of freedom on "FACE 1" and "FACE 2" should I constraint to rotate "GEAR A" and "GEAR B" around the axis X.
Degres of freedom:
Displacement: x, y and z
Rotation: x, y and z
I have attached the picture.
https://files.engineering.com/getfile.aspx?folder=...
Thanks so much in advance.
Henry
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
White Paper - Comparing Multi-Patterning at 5nm: SADP, SAQP, and SALELE
Self-aligned multi-patterning techniques such as SADP, SAQP, and SALELE are increasingly popular at advanced nodes, but each process has its pros and cons. IMEC and Mentor, a Siemens business collaborated to identify potentially less-obvious process and design limitations and trade-offs between the three SAMP techniques. Learn more in this paper. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
