Immediate settlement of footing
Hi guys I'm now designing for footing with 7m x 14m dimension
I have some questions on calculating immediate settlement of shallow foundation on granular soil.
Based on my knowledge, the immediate settlement can be calculated as
(S = q * B * (1-u2)/E)
S: settlement
q: unit stress on soil
B: lesser dimension of footing
On the other hand, by elastic theory
S = H x q/ E
H: soil depth
I notice first equation is linearly proportional to width B (I know there are some factors relating to dimension of footing and depth), second equation however, has no relationship with width. How should I consider while using this equation?
Thank you
RE: Immediate settlement of footing
I would use a geotekkie if the answer was critical... They're the 'juju' boys when it comes to deflection calculations, and, their numbers are sometimes an educated guess.
Dik
dik is correct. Heck, your immediate settlement may be peanuts compared to what might come later.
Quote (OG)
Just look at the Millenium Tower <G>.
Dik
step 1: Find some way to obtain the soil modulus (moduli).
step 2: Evaluate the sustained load on the foundation and reduce it to applied bearing pressure for your foundation size.
step 3: Determine the attenuation of load with depth (i.e., Bousinesq or Westergard).
step 4: Make a plot of delta sigma V with depth and overlay that on the modulus profile.
step 5: Integrated delta sigma v with respect to moduli.
So, if you have a 5 ft layer below the footing that has an average stress change of 2,500 psf and the modulus value is 150 tsf, you'd get 0.5 in for that layer. Next layer down may be 10 ft thick and have an average increase of 1,800 psf and have a modulus of 200 tsf. That'd return another 0.54 inches of settlement. Keep doing that and add up the total.
All that will occur, "Immediately." For long term (i.e,. 30 years), we'd add some post-construction strain - like another 30 percent.
f-d
ípapß gordo ainÆt no madre flaca!
On the first of the steps in the fattdad post you need the geotech, so then the other steps may or may not be used.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
