NON-DESTRUCTIVE TESTING
4
Drawing callout material is 17-4 ph CRES per AMS 5643/H1025. Which non-destructive testing is better to carry like Liquid Penetrant testing per ASTM E 1417 or Magnetic particle testing per AMST E 1444 for this material.
Loka
RE: NON-DESTRUCTIVE TESTING
How is the part made and what defects are you the most concerned about?
LP is strictly surface only.
MP will also indicate things just below the surface.
Neither will tell you anything about the interior.
Recommend looking into ASM Volume 11 for NDI techniques and capabilities.
Wet fluorescent MT.
Looks like you are only concerned about machining anomalies or surface cracks. Fluorescent LP or wet fluorescent MT as metengr suggests should be fine for this application and material.
loka23...
Magnetic particle and fluorescent dye penetrant inspection procedures can be successfully accomplished on 17-4PH CRES, any hardness condition.
The NDI procedures callout you outlined is incomplete, IE: (a) Liquid Penetrant testing per ASTM E 1417 or (b) Magnetic particle testing per AMST E 1444
DO YOU KNOW WHY????
When I specify magnetic particle and/or fluorescent dye penetrant inspection for Aircraft parts I typically do so as follows...
Fluorescent penetrant and/or magnetic particle inspect per MIL-STD-1907** Grade A.
**MIL-STD-1907 INSPECTION, LIQUID PENETRANT AND MAGNETIC PARTICLE, SOUNDNESS REQUIREMENTS FOR MATERIALS, PARTS AND WELDMENTS
This spec is applicable to materials, parts and weldments. It ALSO includes [as part of the Grade A, B, C, D system] all elements required for a successful NDI process callout: when-to, how-to, what-to, etc... and is very specific as to accept/reject criteria.
The 'how-to' ASTM specs you cited do NOT describe vital defect accept-reject criteria. MIL-STD-1907 lists very specific defect types/sizes/densities [#-per unit surface area] that are permitted within the grade category.
NOTE. I recommend a quick and dirty way to add a more rigorous/generalized accept-reject criteria, to the proposed callout (a) Liquid Penetrant inspect per ASTM E1417 or (b) Magnetic particle inspect per ASTM E1444., thus...
add...
NO detectable defects permitted during final NDI inspection after blending-out all defect indications to maximum limits as permitted by [drawing][repair data][etc].
Regards, Wil Taylor
o Trust - But Verify!
WkTaylor....I agree with you except for one thing....the poster is not in the US and therefore MilSpecs do not apply. He has to specify to prevailing specs.
Ron... may be, may be-not...
17-4PH CRES per AMS 5643/H1025
Liquid Penetrant testing per ASTM E1417
Magnetic particle testing per AMST E1444
Regards, Wil Taylor
White Paper: Industrial Control Basics: Contactors
A contactor is an electrical device used for switching an electrical circuit on or off. Considered to be a special type of relay, contactors are used in applications with higher current carrying capacity, while relays are used for lower current applications. Download Now
Research Report: State of IoT Adoption in Product Development 2019
This research report, based on a survey of 234 product development professionals, examines the current state of Internet of Things (IoT) adoption by product design teams, its perceived importance, and what features and capabilities teams consider important when making decision about adding IoT functionality to their products. Download Now
Research Report: Augmented Reality for Maintenance, Repair and Overhaul (MRO)
The term Industry 4.0 denotes a cluster of technologies that’s poised to fundamentally reshape manufacturing and bring about a new industrial revolution. These include 3D printing (AM), the Industrial Internet of Things (IIoT), artificial intelligence (AI) and mixed reality technologies, more commonly known as virtual reality (VR) and augmented reality (AR). Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
