ANALYSIS OF FRAME LIFTING
Dears,
I have modeled a frame and analysed for in-process & lifting condition. during in-process i got excessive stress due to temperature load. So i provided 10Kn/mm spring at Fx & Fz to release the same. But what should i do while making concrete foundation to get this spring action.
During lifting analysis i am getting very high axial forces in slings & instability is more. hence I provided releases in slings & frames to make it stable. but sling force reduced to very less value, which shall not be correct. please refer attached models& advise on the supports in both condition.
https://files.engineering.com/getfile.aspx?folder=...
RE: ANALYSIS OF FRAME LIFTING
I don't know that you can. For some cases, I've modeled the stiffness of the anchor bolts (in bending) to get some relief in certain situations (temperature to name one)...but that's about the limits of what you can do for a hard connection. There are some slide plate options for process equipment. (Google teflon slide plates.) I've used them myself.
Overcoming Cutting Tool Challenges in Aerospace Machining
Aerospace manufacturing has always been on the cutting edge, from materials to production techniques. However, these two aspects of aerospace machining can conflict, as manufacturers strive to maintain machining efficiency with new materials by using new methods and cutting tools. Download Now
3D Scanning in the Automotive Industry
With over 100 years of production history, the automotive industry has been at the forefront of manufacturing technology since its inception. Whether the transformative technology of the day was the assembly line, the integration of robotics into the manufacturing process, or the switch from steel to aluminum frame chasses, the automotive industry has consistently implemented advanced technology into its manufacturing and production workflow to improve manufacturing and product performance. Today, the same is true. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
