Mass Prop set up for assemblies
Because something is not set up properly - either the models or your interpretation of what the right answer should be.
To be more specific we need more specifics, like why do you think they are wrong and what in particular is wrong?
Add the mass property values to your model tree to be sure they are all correct and you can see them all in the same place.
Ben Loosli
