SMath Problem 2
You need a "Boolean" equals for "NDX.service = 2"
Erase the := type of equal sign, and select it from the RH menu, or and type <Ctrl>=
STF
Thanks, I didn't realise there was an equals sign in the Boolean values... Tried the equals sign in the Arithmetic as well as the keyboard and it wouldn't accept either.
Dik
:= is specifically for what are called assignments, i.e., you're assigning to the LHS the value of the RHS.
<CTRL>= is specifically for testing values, and returns a TRUE when both sides are equal
= is specifically for displaying the value of something
TTFN (ta ta for now)
Thanks, IRS...
Dik
