LISP - Running through every sheet and zooming out 3
JuanBC
141
Does anyone have a LISP routine that runs through every layout of a drawing? I would like to adapt it to a lisp that automatically 'zooms out' every sheet in a .dwg
Thanks!
JBC
"The more I read, the more I acquire, the more certain I am that I know nothing"
Not quite what you're asking for but it's what I do...
Add this single line to your ACAD.LSP file:
[ul][li](defun c:ZE () (command "zoom" "e"))[/li][/ul]
then:
[ul][li]start in model space[/li]
[li]<CRTL>-<PgDn>[/li]
[li]ZE[/li]
[li]<ENTER>[/li]
[li](repeat for as many sheets as the drawing has)[/li][/ul]
Since your right hand can quickly type "CRTL-PgDn" and your left hand can hit ENTER this should take about 1/2 second per sheet.
If your drawings have LOTS of sheets, then additional automation is called for, of course.
Considering some alternatives: do you use named views? Do your drawings always have the same number of sheets? If every sheet has a named view, and you were prepared to preset the named views in the template, and the template can have all of the necessary sheets already created, then you could have this set up in advance. Then a single LISP command could be used to re-size all sheet views per the named views. Takes a lot of pre-configuration, as you can see.
STF
Hi STF,
I am also used to doing the same thing but sometime I work with drawings with multiple layouts and i'ts quite annoying
After posting this thread I found this code. Hope it helps you
Code:
;; Zoom Extents all Layouts  -  Lee Mac
(defun c:zea ( / app ctb doc )
    (setq app (vlax-get-acad-object)
          doc (vla-get-activedocument app)
          ctb (getvar 'ctab)
    (foreach tab (layoutlist)
        (setvar 'ctab tab)
        (vla-put-mspace doc :vlax-false)
        (vla-zoomextents app)
    (setvar 'ctab ctb)
    (princ)
(vl-load-com) (princ)
JBC
I like this, thanks!
I use ZE also but after it is done I zoom to 0.98x to add a little border
(DEFUN C:ZE () (COMMAND "ZOOM" "E" "ZOOM" ".98X") (PRINC)) ; Zoom E then .98X
Also ZP
(DEFUN C:ZP () (COMMAND "ZOOM" "P") (PRINC)) ; Zoom P
also Z9
(DEFUN C:Z9 () (COMMAND "ZOOM" ".95X") (PRINC)) ; Zoom .95x
and for moving around in and out reviewing drawings
(DEFUN C:ZD () (COMMAND "ZOOM" "D") (PRINC)) ; Zoom dynamic
Hi!
I'm glad you like it, and thanks for the improvement! I'm going to use it
JBC
