Fine pitch spur gears.
DocSergey
RU
Can anyone tell me which standard for fine pitched gears are still active and commonly used please?
DIN 58400/ 58405/ 58412 are withdrawn, there is no ISO standard for gears with module below 1 mm
(iso 1328-2 defines total radial composite tolerance for module from 0,2 up to 10, but runout is only from 0,5 and higher),
have no access to british standard and AGMA would be difficult to integrate into our employees minds (with things like circular pitch, not module).
Thanks in advance.
