Changing properties standard shape reference point location by API function .pval(51) in v10.3.1
The default location of reference point for a standard shape in FEMAP is "1". I want to change it to other location by using the API function .pval(51) e.g. to point 7. I have tried using the command pr.pval(51) = 7 then, .ComputeStdShape, then pr.Put(ID) to update the properties. There is no error nor warning messages after running the script. But the reference point was not updated, still at location "1".
If the reference point was changed manually throught tge "Properties" dialogue box and then read the new value by using the function Msgbox "xxx: " & pr.pval(51), the new reference point location "7' was displayed.
If the command .ComputeStdShape was removed or .pval(51) was moved to a location after the .ComputeStdShape command, the reference point location was updated as expected.
Is it true that the command .pval(51) CANNOT be used before the command .ComputeStdShape?
RE: Changing properties standard shape reference point location by API function .pval(51) in v10.3.1
faremusai,
For future inquiries, please use the regularly monitored FEMAP forum found here:
https://community.plm.automation.siemens.com/t5/CA...
You are close - the issue is that you need to use "pr.Put( pr.ID )" BEFORE "pr.ComputeStdShape(...)". Otherwise, you have not updated the property with your new reference point and you will always be computing on the original, unchanged, property.
Thanks for the explanation.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
