Flex MSE vs. Rockery wall
Anybody have experience with Flex MSE for retaining wall
http://www.flexmse.com
How was it compared to conventional rockery wall in term of durability, cost and ease of implementing?
Thanks!
RE: Flex MSE vs. Rockery wall
Hi ANgK,
I'll let other users weigh in on their experience with Flex MSE. Please let me know how we can be of further service from a manufacturers side. If you don't already have access the secure area our site please reach out via www.FlexMSE.com/contact-us and we'll happily set you up with access to our full CAD library, Testing and Technical documents as well as Design and Estimation tools. There are also a number of case studies on our website for your review including this project: www.FlexMSE.com/kirkland.
Thanks for your interest!
Mike.
Rockery is a gravity wall system, FlexMSE is a MSE wall or reinforced steepened slope system. The excavation, backfill, and construction requirements are considerably different.
It would really have a lot to do with the height of the walls you are considering. I suspect that the "rocks" in a rockery that are thousands of years old may win the durability contest if that is your concern and may do better in a fire as well. Cost has a lot to do if rocks are locally available and the rockery form of construction is common. They would be cost prohibitive in Florida for example. Rockeries are very common in parts of the US and fairly economical if the heights are reasonable.
MSE walls including FlexMSE have their considerations as well and work well in many applications also including seismic conditions. Just depends on what you are trying to accomplish and where the project is located.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
