Contact US
CPI Separator Design Assistance
We are on task to review and FEED design a CPI separator and require design assistance in terms basic design guidelines or with spread sheet
NM
RE: CPI Separator Design Assistance
WE really can't provide assistance unless you have a specific question?
Ashtree
"Any water can be made potable if you filter it through enough money"
Ash
We need to design a system for 50 m3/hr with a feed oil of 150 mg/l, 100 mg/l TSS with an oil droplet size of 30 micron and above.
Removal of oil should be >90%. I am looking for design guidelines or simple spread sheet to see the basic sizes of the tank, required plate pack, pack volume
Do you know what the SG of the oil is?
My assumption is , that given you are planning to use a CPI that the oil is mostly non emulsified. Is this correct?
Plate separators generally work better with oil drops 60 micron or larger. This is especially important because you are looking for high removal efficiencies.
As a starting point you can process about 0.5m3/hr per m2 of plate area if you have 60 micron or larger oil droplets and the SG is about 0.9.You are probably going to need a lot more area or a lower loading rate if most of your droplets are a lot smaller than 30 micron. Alternatively the removal efficiency will be lower.
Ashtree
That is a relatively small oil/water separator.
Most users will buy a pre-engineered and prefabricated unit rather than constructed a custom made unit.
Refer to the brochure from Siemens:
Siemens Link
My comment above should read:
"You are probably going to need a lot more area or a lower loading rate if most of your droplets are a lot smaller than 60 micron."
I would agree with bimr comment on design and construction of such a unit. Buy one off the shelf if you can. But look at the plate area, flow rates, removal efficiencies, acceptable solids loading etc of the units you are considering.
Ashtree
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
