I’m hoping to find an MS9556 A286 fastener endurance limit to use for fatigue analysis. I find reference to numbers which vary significantly.
A simplified picture of the fastener installation/assembly is attached.
A simplified description is a stack of aluminum plates clamped with two MS9556-32 bolts.
o The minimum specified MS9556-32 RT ultimate tensile strength is 130 ksi.
o The minimum specified MS9556-32 RT .2% offset yield strength is 85 ksi.
I calculate an installed preload of ~1200 lbs per bolt at RT with an installed torque of 40 in-lbf.
o The installed torque range is 30-40 in-lbs.
o The thread tensile stress area is ~ .0200 in^2.
o Installed stress is ~ 60 ksi.
I calculate a hot operating temperature load of ~1900 lbs per bolt due to thermal growth.
o The calculated hot operating load is ~110% of yield strength.
o Operating stress is ~ 95 ksi.
o Should I try and lower this stress?
The bolts are subject to cyclic tensile loading only.
o Nominal load is ~1550 lbf. (77.5 ksi)
o Alternating load is +/- 350 lbf. (17.5 ksi)
I need to superimpose the nominal or mean and alternating stress on a goodman diagram to confirm I have adequate fatigue life. I think I’m ok on a Goodman diagram [URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1523397314/tips/cross-section_qsuilv.tiff[/url]with a UTS of 130 ksi and an endurance limit of 65 ksi. I’m just using 50% of the UTS. What should I be using for an endurance limit?
